V70 T5 Rear Booster seat
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
stockton
Post by stockton »
This is minor but does anybody know where to buy a replacement passenger side rear booster seat or booster seat mechanisim. Seems the locking mechanisim under one of ours is jammed or the cable has come loose, because the release handle has no tension on it and the seat will not come out of the down position. I might can fix it, assuming I can get the booster out of the seat without releasing it from the down position.
Thanks
Andrew
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
This is a common problem.
Almost all of these cables fail at one point.
Take it to a Volvo dealer. This is the cheapest alternative then trying to buy a seat.
You would have to buy an entire used rear seat (with boosters)!
stockton
Post by stockton »
I would rather not replace the whole booster, so there is a replacement cable mechanism? How do you remove the booster seat, to replace the cable mechanism, if it is locked in the down position.
Thanks
Andrew
JRL
Post by JRL »
stockton wrote:I would rather not replace the whole booster, so there is a replacement cable mechanism? How do you remove the booster seat, to replace the cable mechanism, if it is locked in the down position.
Thanks
Andrew
There's a little trick but unfortunately I can'r explain how to do it however using a different angle to pull on it works at times.
Try pulling on the handle and pulling straight forward on the seat, do not try to lift it UP and forward, wiggle it around. Sometimes this works too.
I don't think you can replace just a booster seat in itself anyway without buying an entire rear seat with boosters
