Transmission Fluid?
harley43
Transmission Fluid?
Post by harley43 »
just got my 1998 S70 Turbo.
woud like to do the flush in the forum.
Completly confused,Volvo,Detron 111,Mob.
Which is the correct fluid?
thanks again.
pfeener
Been thanked: 2 times
Post by pfeener »
Dextron III is the correct spec for your 4 speed trannie.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Yes, true....but you can use Mobil-1 Synthetic ATF without issue (many of us are using it)...may actually be a better alternative because it is synthetic and will probably last longer before breaking down.
harley43
Post by harley43 »
thanks for your response
Any issues with leaks using synthetic?
Also can I use the method on this site for flushing.IE-drain tranny
approx 3 to 4 quarts refill with synthetic?run 500 miles repeat till clean.
thanks again
Have had no leaks with the synthetic. Not sure about a drain and fill with synthetic when regular ATF is in there....but don't think it will hurt.
harley43
Post by harley43 »
thanks again for your help
