1996 volvo 850 glt intermittant ABS light
Occasional ABS light. Brakes work fine, fluid levels are good. What is the most likely cause? Is there anyway to narrower this down? Maybe get rid of the light?
just clean your sensors. They are found just above the hub of each of the wheels. The front ones get a lot of brake dust and road film on them.
Once you clean these you will most likely find the light going off less.
I would not take the bulb out, because eventually ifthe system goes altogether then you might cause a real issue specially if someone else is driving your car and is not aware of the problem.
THE FLEET!:
93 854 GLT 20v non-turbo 435,000 KM +
94 854 20v non-turbo 215,000 KM ..new engine
87 745 B230 non-turbo 250,000 KM (newest edition Jan '07)
86 244 GL B230 non-turbo 460,000+ KM
- 11 Replies
- 2824 Views
Last post by precopster
- 344 Views
Last post by Gunners
