Is this something that can be replaced easily and/or without spending too much money?
Here are two pictures of the driver side, but I would need it for both the driver and passenger sides:
You can do the whole deal in an hour if you don't need a concours job but just very acceptable.v850 wrote:Not a bad idea, it's a bit of work, but could work very well. I'm going to check with the stealership in case they somehow have them cheap or something, but otherwise I'll probably end up leaving it as is, because sand blasting it doesn't sound like too much fun. Sanding, priming, spray painting, etc. isn't too hard or big of a deal because most of it is just prepping the area around it to not get the paint in other places.
Thanks for the reply, I appreciate it.
