1994 940 turbo cooling fan problems
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
pburchins
Post by pburchins »
Hello,
I am having problems with my 1994 940 turbo. The cooling fan won't turn on. I have swapped out the cooling fan relay and it did not help. I have run 2 wires directly from the battery and tested the fan and it does run on both speeds.
I will idle the car with the A/C on and it will overheat. There is no temp sensor on the radiator. Is there one on the engine ?? At this point, I am at a loss........any suggestions or recommendations would be appreciated !
Thanks !
Patrick
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The cooling system temp sensor is on the left side of the cylinder head under the intake.
Have you pulled any codes on this?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
