No Heat on Passenger side
bsr16
Post by bsr16 »
1994 850 Turbo.
when the fan is on, only cold (really cold) air is coming from the passenger side vents. i have to close off the center two vents also. when the defroster is on, only hot air comes out of the left side. the passenger side only blows cold air. which means no defrosting. HELP.
also, is there anyway to insulate the radio area, the ashtry and the center console. my right hand is just starting to thaw out. :cry:
volvo tech
Post by volvo tech »
sound like you have a bad dampper motor is bad. you need to checked for code
