Vibration at low speed Topic is solved
nsimha
Post by nsimha »
Hi:
I have a 2000 V-70 with 38K miles. At low speed i.e. when the car just starts moving, there seems to be excessive vibration. I can also reproduce it, if I hold the brake and give some gas.
Any hint? The engine mount is in a decent condition.
Thanks
Nick
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
How about the lower mounts? Is it skipping? Does it vibrate when in park and you rev it up or just in drive?
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Nick
Post by Nick »
Just when I start (the first second or two) - it is smooth when the speed picks up...
Thanks
Nick
Nick
Post by Nick »
to clarify - the vibrations occur when the car just starts moving...
thanks,
nick
Tsquared
Has thanked: 1 time
Post by Tsquared »
How are the wheels and tires? A flat spot on either can cause a vibration.
Breake Rotors?
Is there a roaring sound also? This could point to a bad wheel bearing.
It is difficult to trouble shoot over the internet...
Good Luck,
T
'11 C30 T5
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Hell yea it is. Maybe one day I'll have a video-upload feature, so we can see and hear these problems. :D
I'd agree -- lower engine mounts, out-of-round wheel, unbalanced wheel.
Although with a lower engine mount you'd probably notice some movement when shifting from R to D etc.
Also -> Amazon link
am0220
Post by am0220 »
Nick,
I'm interested to see what yours turns out to be. I've just recently replaced my lower right mount and upper mount to see if it would help the vibration in the steering wheel, but it made no noticable difference. I also get a big "kick" in the steering wheel when the car first starts. The vibration I have isn't major, just annoying. When driving, I feel the engine vibration, especially when I turn slightly, like a small correction on straight-line driving. Mine seems much smoother when coasting. I don't think, based no what you've described, that your problem has anything to do with brakes, since you would notice a definite wobble/pulsing braking when you apply them if it were warped rotors, etc. Sounds like you feel it when you accelerate/raise the idle speed.
Let us know if you find what it is. Likewise, I will post the answer if I finally crack the problem.
Good luck!
Anthony
'98 S70
Ride
Post by Ride »
Maybe front CV axles? Would certainly explain the change in vibration between turning and straight line driving.....could also explain a vibration or shudder under initial load.....
Just a thought.
Ken
93 850 GLT
Canada
Nick
Post by Nick »
I am taking it to the shop today - they are gonna replace the lower mount. Thanks for all the suggestions. I will let you know if this fixes the problem (the technician said he wouldn't be able to guarantee it)
Regards
Nick
Ride
Post by Ride »
Nick - where are you located?
93 850 GLT
Canada
