1991 240 Engine Knock
I recently just bought a 91 240 with 176k miles on the odometer. I bought the car to repair and just drive, but I am needing help diognosing the problem. There is a knocking noise coming from the motor that isn't constant, but only stops for a second or two. The oil looks clean in the motor and the timing belt was changed around 136k miles and is still intact. There is oil coming from behind the timing belt cover, but not sure where. I took the valve cover off and can't see anything obvious but suspect I'll have to keep digging? How should I go about finding the problem? It looks like the car has been kept up for service, but the fellow I bought it from didn't know what was wrong with it. Thanks for the help.
outofworkjoe
- Year and Model:
Piston slap is common, at start up what type engine oil are you useing?I like Max life 10 w40.
1991 volvo 240 207000 my car/1993 volvo 940 turbo 160000 wife/1989 245 267000 sons
- volvoaddict007
- Year and Model: 760 Turbo
hi tylka,
A spun rod bearing should be pretty obvious. The 240 pistons don't have skirts so they slap around in there and can start sounding like tractors even after warmup but they can keep goin. Even though the sound is there after warm up is it more pronounced when cold ?
If you take a piece of garden hose/ fuel line and put put it up to the oil pan ( and your ear of course) it should get pretty loud near the bad bearing but unless that sounds like a ballpeen hammer even from outside the car, my gut feeling is you just have a slap happy 240.
I would ask the previous owner how long the noise has been there. If it's been a long time then it's not a rod bearing. If it came on suddenly and recently then you may be correct.
A spun rod bearing should be leaving metal particles in the oil as well.
176k is nothing for those bearings...
va007
va007
1990 5 speed 760 Turbo Wagon 310K.
( '91 940 turbo eng. + trans.)
Konis, diesel springs, 2.5" exhst., 850 T5 wheels
1993 300ZX 2+2, 171K
1999 Ford Windstar LX, 90K
- 2042 Views
Last post by cn90
- 1714 Views
Last post by 93Regina
- 803 Views
Last post by volvolugnut
- 460 Views
Last post by BoxesAndSquares99
- 11757 Views
Last post by MoosePond123
