Hey guys,
Just changed my maf sensor as the fault code came up recently, I put in the new one today as I was anxious to see if there was an improvement but their doesn't seem to be much difference. My mechanic is going to reset the fault code tomorrow for me-will that have an affect or should I see an immediate fix? I still have slightly rough idling, and (at times) little turbo boost, all symptons of a bad maf sensor I believe. Thanks for any help.
Maf sensor, S70 T5, 1997
- Has thanked: 17 times
- Been thanked: 35 times
Resetting codes will show an immediate change to how your car is running. Have you checked fuel filter, pump, relay, wires, rotor and plugs as well- also the things that cause bad idle or rough running.
daveaherne
- Year and Model:
You were right-fault code reset, rough idle gone and consistent turbo boost, happy days again.
- 3157 Views
Last post by itsmekirby
- 2015 Views
Last post by Scholz
- 1924 Views
Last post by albertoVO5
- 26 Replies
- 6578 Views
Last post by ChadLee
- 11 Replies
- 4862 Views
Last post by matthew1
