V70: What is difference between 140/170 hp engine?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Asger
Post by Asger »
The two engines have the same tecnical specifications.
I want to buy at new Volvo V70. Have to pay appr.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2656 times
Been thanked: 1248 times
Post by matthew1 »
I'm no expert on UK models, but I believe the difference between those two is that the 170hp has 20 valves and the 140hp has 10.
Four valves per cylinder versus two = better breathing = more horsepower. The software on the chip is almost certainly different to account for the different hardware. I would guess that a chip upgrade on a 140hp, if even available, would not bring you safely up to 170hp.
Also -> Amazon link
petershen1984
Post by petershen1984 »
Yes Matthew, you were right, it's SOHC (10 valves) versus DOHC (20 valves).
http://autozine.kyul.net/html/Volvo2.htm#S80
Peter Shen
1992 Volvo 960 (Silver)
