87 240dl wagon not turning over
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jefftaylor73
Post by jefftaylor73 »
Hello all,
I just bought a 240 DL wagon 87 automatic. Just changed the belts on it and thought it was working fine. Mileage is approx 200k odometer is broken. Car was running fine and today all the lights came on and the car shut off and steering was hard. It has a new battery and the belts are tight. Basically it acts like it wants to turn over but doesn't. I also hear a pinging noise after its off kind of like something dripping on metal. I checked the oil and transmission fluid and they are full. Any clues as to what it can be. I am new to a volvo.
Thanks,
Jeff
waynej
Year and Model: 1999 S70
Post by waynej »
Did you change the timing belt? If not do you know when it was last changed?
Remove oil filler cap, shine flashlight in, have someone try to start engine. If cam isn't turning you just broke a timing belt.
jefftaylor73
Ok, The timing belt looked fine when looking at it. It ended up being the fuse block under the electronic (electric) fuel injection system, it
