1986 240Dl wagon braking problem !
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
RichyRich514
Post by RichyRich514 »
ever since i bought the car which was less then 2 months ago the brake pedal seemed soft but the previous owner changed the rear pads and discs not the front so i thoguth it was alright then today i back out start driving get to a red light and there was no pressure in the pedal at all it went to the floor then i pumped the brake and it went back to normal !
what can be the problem ?!
thanks in advance!
sseir39
Post by sseir39 »
If you just replaced a set of pads you moved the pistons back into the caliper. This would cause the pedal to go to the floor without first pumping the brakes. Could be air in the system if it has not been bled.
RichyRich514
i dont knoe what the previous owner did but im guessing theres air in the system.
wojeepster
Post by wojeepster »
You may have a worn master cylinder, allowing brake fluid to go past the seals. If after bleeding you can press down slowly and put pedal to floor this may be the case. If you need one check around prices vary widely when I replaced mine I bought a rebuilt unit for $23 and three years later it still works fine. Other stores wanted $185
RichyRich514
yeah today i got into the car and without even turning the car on the brake goes to the floor slowly!
so does this mean for sure its a worm master cylinder?
since i dont have a shop of my own anymore at the moment i have to go to someone elses garage and i dont plan on paying somoene a 100$ for a diagnosis and estimate of how much and what is needs .
so if it is the master cylinder ill buy one myself and get them to install it for me .
so is that the problem?
RichyRich514
TTT
swingline
Post by swingline »
i am having a similar problem. IPD sells this http://www.ipdusa.com/Volvo-200/Brakes/ ... 9-255-426/
for bleeding brake lines. maybe this would be a place to start to know for sure if its air in your lines creating your problem.
anyone know if a fruit tree sprayer from lowes would do the same thing with an adaptor?
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Not necessarily. If you haven't bled the brakes then it could still be air in the system which would also allow the pedal to go to the floor. If you are sure there is no air in the system then it probably is a worn master cylinder.
It depends on the working pressure of the sprayer. Most power brake bleeders work at about 25 psi.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
swingline
Post by swingline »
thanks bill, i went and ordered the pressure bleeder. i bet a fruit sprayer would work but i want to do this right the first time.
richyrich i have not done the work yet but from what i have read it does not seem like a very serious thing to bleed your lines and install a master cylinder if you need it. couple bolts and two hoses and thats it.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I have the pressure bleeder and it really makes the job much easier...money well spent!
