Variation on the Airbox thermostat modification.
I have a 96 850 GLT, 132,000 miles and the when looking at doing the airbox thermostat, my thermostat is vacuum powered. My mileage has been around 20mpg regardless of city or highway.
When looking at the flap that closes off the hot air, the flap did not close completely, therefore hot air was always being introduced.
Since the thermostat area is different, there was no way to force the flap open with dowels, etc. I screwed a long screw through the themostat housing to force the hot air flap closed. I have seen little written about this type of airbox thermostat.
This made a large difference in acceleration, power and hopefully my gas mileage.
Vacuum powered airbox thermostat modification
jchrisloyd
- Year and Model:
2002 Volvo S80 2.9
1996 Volvo 850 GLT
1996 Volvo 850 GLT
hausmeister
- Year and Model: 1995 850T5-R
- Has thanked: 276 times
- Been thanked: 85 times
As I also tried this ( https://www.matthewsvolvosite.com/chat/p ... 9522#49522 )but I did not notice any (positive) differnce.
What I found out about the vacuum powered valve is that it is either fully open or fully closed. I believe the older version is different and also operates "in between".
Anyway, it did nothing for me, except me wanting to put it back in as soon as it got cold.
Also you do not have to modify the airbox, just simply dismantle the duct, remove the flap and block the hot air side if you want to do this. That way it can be reversed any time.
850 T5-R '95 auto
jchrisloyd
- Year and Model:
Thanks hausmeister,
I noticed you have an S70, while mine is a 96 GLT. I was looking on FCP, and noticed an Intake Air Temperature Sensor, and saw a few references on the net that this sensor determines when to put vacuum to the vacuum type airbox. I do not know if this is correct, and if so then my 850 does not have this sensor.
I'm starting to wonder if the prior owner might have put a newer style airbox in my car. They had it connected to the vacuum tree, and therefore it was always in the "hot" position.
any thoughts anyone?
2002 Volvo S80 2.9
1996 Volvo 850 GLT
1996 Volvo 850 GLT
- Has thanked: 17 times
- Been thanked: 35 times
Have you seen this? Click and scroll down (of course, everyone got off topic, but it is closer to what you're asking): https://www.matthewsvolvosite.com/chat/p ... hp?t=13141
tjts1
- Year and Model: 96 855 NA 5 speed
- Been thanked: 4 times
I'm really surprised you have a vacuum operated airbox on a 96 GLT. Our base 96 850 5 speed has the regular thermostat as pointed out in the above link. I thought those showed up on S70/V70s.jchrisloyd wrote: I'm starting to wonder if the prior owner might have put a newer style airbox in my car. They had it connected to the vacuum tree, and therefore it was always in the "hot" position.
hausmeister
On mine there is a valve/switch/Thermostat in the top airbox cover. from there are hoses to the vlave below and to the vacuum tree. Maybe its not connected correctly? You can test the calve by sucking on one of the hoses and see what happens. If i remember correcty, it should open to hot air if you apply vacuum.jchrisloyd wrote: I'm starting to wonder if the prior owner might have put a newer style airbox in my car. They had it connected to the vacuum tree, and therefore it was always in the "hot" position.
850 T5-R '95 auto
- 3419 Views
Last post by SuperHerman
- 15687 Views
Last post by 93Regina
- 1146 Views
Last post by erikv11
- 702 Views
Last post by dosbricks
- 2550 Views
