S80 Front & Rear Brake Disc & Pad Replacement, 1999-
This topic is in the MVS Volvo Repair Database » S80 Front Brake Disc and Pad Replacement
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
NOTE: The following is for entertainment purposes only. We assume no liability if you try to do this yourself. Making a mistake on your brake system can result in property damage, personal injury and/or death. Yes, you could lose control of your car and hit someone or something. Consult a qualified technician. Do not try this at home. You have been warned.
Here's how I changed the front brake discs and pads on my 2001 S80 T6. It has 76,000 miles. The pics reference the right front wheel, but the procedure is the same for the left front wheel.
(Looking for S80 rear brake pad and rotor tutorial?)
Pic of my right front wheel that I'll be working on. This one is 17":
Here's one of the new discs:
And the new pad set:
I put the car in park, set the parking brake, and put chocks under the left side wheels. I loosened the lug bolts with a 3/4" socket and a breaker bar. Then I used a floor jack under the front jack point to pick the car up just enough so the tire cleared the driveway. I then removed the lug bolts and the wheel.
Here's the old, worn out disc:
A top view showing how worn the disc is. I'm assuming it's original. The service limit is 25mm in thickness, according to Brembo. I'm sure this disc is at or below that:
I used the "poor man's piston compressor" (two screwdrivers) to push the piston back into the caliper all the way. This clearance is needed for the new pads to fit over the new disc. I applied constant, firm, outward pressure on both screwdriver handles until the piston was forced all the way back into the caliper.
Closeup of screwdriver between pad and disc. Some people might say I shouldn't do this because of possible damage to the disc and/or pads, but I'm replacing them both anyway, so it doesn't matter. Also, you can see the huge groove that's been cut into the disc by the pad. The disk was originally the thickness of the lip at the outer edge.
Notice the gap between the disc and pad after piston compression:
This pic shows the top mounting bolt that needs to be removed. It's in the center of the pic and is a 15mm bolt.
Removing the top bolt:
Removing the bottom bolt:
I set the caliper on a paint can to prevent strain on the brake hose:
Removing the disc retention bolt. It's 10mm and also the stud for wheel alignment on the hub. I liberally applied WD40 to the lug bolt holes and disc retention bolt. I had to be very careful not to strip this bolt. There's only one hole in the hub for it to fit into; if that's stripped, I'd have to drill and tap a new hole or install a new hub. :( .
Here's the retention bolt 1/2 way out:
Hammer time! After the retention bolt is removed, a few taps with a hammer are needed to break the disc loose:
And the old disc is off. The metal bar with the bolt through it laying next to the disc is the steering stop - both caliper bolts go through this stop before screwing into the caliper:
Frontside view of the new disc (left) next to the old disc:
Backside view of the new disc (left) next to the old disc:
Edge view of new disc (left) next to old disc:
I wire brushed the hub to remove the rust and insure the surface was clean for the new disc:
Then I cleaned the new disc with brake parts cleaner, placed it on the hub and fastened it with the retention bolt. I put a dab of Loctite on the bolt to keep it from working loose.
I pried the inside pad out of the piston with a screwdriver:
I removed the spring from the outside of the caliper with a screwdriver:
I slid the pads to the center of the caliper and removed them. Here is the old inside pad next to a new one (bottom). You can see how much thicker the new pad is. The old pads are probably still serviceable, but new ones will bed into the new disc better and I only wanted to do the work once, so I changed them now:
I slid the new pads into the caliper. It took quite a bit of force to get the springs to snap into the piston on the inside pad, but the outside pad slid into place easily:
Then I placed the caliper over the new disc:
I inserted first the top bolt, remembering to put the steering stop on:
Then the bottom bolt. These had to be really TIGHT. After all, they hold the brakes to the car. I put Loctite on both bolts. The steering stop is the metal bar to the left of the ratchet handle.
I stepped on the brake pedal a few times to push the pads into contact with the disc, then reinstalled the spring:
The finished product:
I then reinstalled the wheel, lowered the car to the ground, and torqued the lug bolts down (Volvo recommends 103 ft-lbs). I repeated the process for the left side wheel.
The parts cost about $165. I have no idea how much a Volvo dealer would charge for this service, but I assume it's a lot. Remember, don't try this at home!
To see how the rear brake pads are done, go here: S60 and S80 Rear Brake Pad Sevice. The rear disc procedure is basically the same as the front.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Great write-up! Thanks for adding this to the repair database. S80 owners will love you! :mrgreen:
vegasjetskier
After almost a year and a half and 12,000 miles (I know, I don't drive very much) on the OEM replacement parts, I was getting severe brake shudder at freeway speeds and moderate shudder in around-town driving. Here at the coast everything corrodes very rapidly, so I decided it was time for some new parts. Since the OEM didn't last long, I decided to try some aftermarket parts to see if they would do better.
Also, in the procedure in my first post above, I didn't show removing the pins in the caliper to take the brake pads off. I'll show that now. You'll need a 7mm Allen (hex) bit to do it. When you get the pins out you will be able to clean and lube the caliper holder and caliper better. Also, if you're just doing the pads and not the disc, you can just remove the pins to get to what you need to.
Start by prying out the anti-rattle spring and compressing the piston back into the cylinder as in the post above. Then remove the plastic caps at the back of the pin housing by prying with a fingernail or small screwdriver. Using the 7mm Allen bit and a wrench, loosen then unscrew and remove first the bottom pin:
Then the top pin:
Take the caliper off and set it on a support. Remove the old pad from the piston by pushing it away from the cylinder:
Clean the fingers on the caliper and apply a thin layer of disc brake grease:
Remove the old pad from the outside of the disc. If you're just doing a pad change, clean and lube the flat surfaces of the caliper holder as show in the photo below and insert the new outside pad. Snap the new inside pad into the piston. Clean and lube the pins and insert them into the caliper. Put the caliper in place and tighten the pins into the caliper holder. Insert the plastic caps. Install the anti-rattle spring as shown in the post at the top.
If you're also changing the discs, see the post above for how to remove them.
Once you have the caliper holder off, clean and lube the flat surfaces shown in this photo:
Change the disc and reinstall everything as shown in the first post in this thread.
Here's a pic of the inside surface of the OEM Brembo disc I took off showing the area at the outer edge where the pad was not touching. I think this a quality-control issue with the Volvo (Pagid) OEM pads:
This is a pic of the outside surface of the OEM Brembo disc showing that the pad was covering all the way to the edge, but it wasn't touching in a large area, so there was no brake effect there. Probably the cause of the shuddering:
In an effort to reduce the rust and shuddering, I decided to buy a set of slotted, crossdrilled, and nickel-plated rotors from Brake Performance. These cost $166 delivered. The slots are machined to the minimum thickness of the rotors so you know you need new ones when the slots are gone. And, they're made in California! http://brakeperformance.com/site/index. ... 2100436011
Here is a pic of the new rotors:
I also decided to go with Akebono Euro Ceramic pads (EUR794 for this car with the 12" brakes) this time because they are supposed to have reduced rotor wear, adequate bite, less than half the dust, and last twice as long as the semi-metallic OEM pads. And, they're made in the USA! I got them for $61 delivered (less than the OEM parts price) from Amazon.com.
Here's a pic of a new rotor installed on the car. I would do something to dress up the caliper, but you can't see it behind the Arraxis wheel. I now have smooth, quiet brakes once again. Hopefully I won't have to update again for a long, long time. :D
mvsuzr
Year and Model: S80 T6 2001
Post by mvsuzr »
Excellent writeup!
Love the look of the new rotors. Do they stop better than the OEM?
On compressing the brake piston, I found that on other cars I've worked on, I've been able to get relatively cheap, adjustable length C clamp across the caliper, with the fixed end on the inside, over the caliper assembly (careful not to pinch the brake line or fitting) and the screw pad of the clamp on top of the outside brake pad. As you gently tighten the clamp, the piston and the caliper assembly retracts. You can feel a sudden change in resistance when the piston bottoms. Remove the clamp and proceed on...
dcarlson12
Year and Model: 1997 850 T5
Been thanked: 2 times
Post by dcarlson12 »
I bought a set of Akebono pads for the front. My original front rotors looked like yours. i.e. the pads did not touch the outer edge of the rotor. I removed the rotors and used a hand grinder to grind the outer edge down and slightly below the 'contact' surface and at a beveled angle. After doing this, I found that the thickness of the remaining material was still thicker than the discard limit. There was still material left on the OEM pads so I put them back. I haven't bought any Akebono pads for the rear. Are you still running OEM pads on the rear with your Akebono pads on the front? If so, just wondering if you noticed any difference in brake 'feel'?
vegasjetskier
dcarlson12 wrote:I bought a set of Akebono pads for the front. My original front rotors looked like yours. i.e. the pads did not touch the outer edge of the rotor. I removed the rotors and used a hand grinder to grind the outer edge down and slightly below the 'contact' surface and at a beveled angle. After doing this, I found that the thickness of the remaining material was still thicker than the discard limit. There was still material left on the OEM pads so I put them back. I haven't bought any Akebono pads for the rear. Are you still running OEM pads on the rear with your Akebono pads on the front? If so, just wondering if you noticed any difference in brake 'feel'?
I have the Akebono Euro Ceramic pads at both ends now. They feel fine and are very quiet. No problems so far.
dcarlson12
Did you run for any time with Akebono's on front and non Akenbono's on the rear?
vegasjetskier
dcarlson12 wrote:Did you run for any time with Akebono's on front and non Akenbono's on the rear?
No, I had Akebono's on the back and stock Volvo on the front for several thousand miles. Didn't notice any ill effects from that.
tshac
Year and Model: 2000 S80-T6
Post by tshac »
Awesome write up......used it but did not even remove the spring......all was easy.
Used BREMBO rotors & NAPA hybrid ceramic pads.
Cost $180 not bad huh. :lol:
2000 S-80 T6
2006 Altima SE-R
2001 Audi A6 4.2V8
2001 King Ranch Supercrew F150
skjmank
Post by skjmank »
Is there a guide for front brake pad replacement that has images? All the links are dead in this tutorial.
2000, V70 Wagon, 307k+, 2.4 liter, awesome.
2000 S80 (N/A)
1994 850 (N/A)
1985 740 (N/A)
