Afternoon guys... I am replacing the door lock assembly on my S70. I found directions on how to do this on VolvoSpeed.com but the pictures on how to remove the door panel are not very good.
Does anyone have a link to how to get them off or a step-by-step. I have searched here and VS but could not find anything. THanks!!
Removal of Door Panel for 98 S70
- Has thanked: 17 times
- Been thanked: 35 times
They just pull out and up from the door (unless you're talking about how to get the panel inserts out) after taking the screw out from the door latch area (you'll see a square plastic cover for one of the main screws), take the surround piece from the door latch out, pull the triangular plastic shield off at the corner of the glass. Once the panel is off, you'll need to disconnect a couple of electrical connectors from the inside so don't just pull it away from the door without looking to see what's connected. Some of the connectors are similar so it might be worth labeling them so you'll get them back the way they came out. The plastic clips that hold the panel on the bottom can break, so you have to be careful when you pull out and up on the panel. If you do break them, they are not very expensive from the dealer. I hope the following diagram will help:
- E Showell
- Year and Model: ‘07 S80 3.2
- Has thanked: 37 times
- Been thanked: 112 times
Thanks, but I'm looking for info about removing a rear door trim. All the Bay 13 and other diagram stuff appears focused on the front doors.
'95 855 auto (sold)
'86 245 manual (sold)
'05 V70 T5 M (totalled)
'06 V70 FWD Auto (totalled)
'02 Honda Insight CVT
‘06 Honda Insight CVT
'95 855 auto (sold)
db130
- Year and Model: 2002 V70 T5
the front and rear door panels are removed the same way, it would be redundant to have a separate set of pictures and diagrams.
i used the bay13 instructions to replace a door lock actuator two years ago and i recently replaced all four door panel inserts on my S70 T5 with leather-stitched door panel inserts from a 2000 V70R using the same method.
2002 V70 T5 169k
2002 V70 NA 249k
2006 Mini Cooper S 90k
2002 V70 NA 249k
- 1759 Views
Last post by VolvoChef
- 2554 Views
Last post by jonesg
- 1192 Views
Last post by halseyfolk
- 579 Views
Last post by obayha
- 2318 Views
Last post by C1ph3r
