Trouble filling tank on '91 740 sedan
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
magoo
Post by magoo »
Hi Everyone,
I have the above car & always have trouble filling the tank. I understand it has a 2 tank system, so you fill the upper tank & it then drains to the main tank. It seems like it'll take enough to fill the upper tank, but it mustn't drain into the main tank as fast as it fills because it'll rarely take more than about 25-30 litres at a time.
Is this normal for this car? Anyone else have this problem?
Thanks,
Shane
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
Post by jonesg »
I've never heard of the 2 tanks in a 740, mine only has one. (1990).
Did you happen to change the fuel pump lately?
My guess is the pickup is not in straight, you probably still have half a tank of gas when the guage reads E. The pickup isn't on the floor of the tank.
Its cocked sideways.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Some 740s were fitted with two tanks. The auxiliary tank actually sits on top of the main tank as shown in this diagram:
The main tank fills first and then the aux tank takes its fuel as an overflow. As the main tank empties fuel drops out of the aux to replenish it.
That breather tube on the top of the aux tank is the only one for both tanks and they sometimes do not breathe properly. Check the tube for restrictions. It is fairly easy to get at. I have also heard that the pump nozzle can restrict the breather whilst the tank is being filled if it is held so that it covers the end of the breather.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jonesg
Post by jonesg »
Is that for head pressure?
or to use a lower pressure pump?
billofdurham
As far as I know it is to give extra range as it increases the tank capacity by about 1/3rd. The pump is the same as for a car with only one tank.
My 740 had the aux tank which made for fewer visits to petrol stations but when I did go I needed a second mortgage..
Bill.
Previously:
magoo
Post by magoo »
Thanks for the responses.
Bill - your drawing helps a lot. Our car has the main tank in front of the rear left hand wheel & the upper tank is in the boot directly behind the back seat. I had assumed the fuel would run through the upper tank into the lower. But with a setup like in your drawing I could see how the main tank would fill easily, but when you're filling the upper tank the fuel may not flow up into the bottom of the tank as fast as the fuel flowing into the filler neck, so it could be fiddly to get the last bit in. The top of the upper tank wouldn't be much below the level of the filler anyway.
The fuel gauge has been erratic for a while & the odometer isn't working (Bill gave some advice on that a month or so back, but I haven't had a few days where my wife doesn't need the car so I can fix it yet), so for all I know the main tank is full most of the time so I'm filling the upper tank a lot of the time.
I did try to gauge the level of fuel in both the tanks by tapping them, but I wasn't having much luck. Maybe if the tanks were steel it'd be easier, but the plastic tanks sounded the same all over to me.
magoo
Post by magoo »
I'll check those breathers too.
