Doesn't keep a spark going / 85 /240dl
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
imaraiza
Post by imaraiza »
I'm new to this forum but would appreciate any assistance troubleshooting this issue. I have a 1985 240 DL. A few days ago, the car came to a complete stop. To my investigation, I found that the spark plug cable from the cap to the coil had severed. Having replaced that, It seems that the engine will turn but won't stay running.
I've replaced the dist. cap, spark plug cables, ignition coil, fuel filter (to make sure), battery and battery cables and it still won't stay running. I've since taken it to a local mechanic and he was unsuccessful at getting it running as well. Any help or suggestions would be great.
Thanks - 240DL
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
You seem to have replaced most of the easy to see parts that can cause a spark failure. When you had the distributor cap off did you check the rotor arm for burning?
Are you getting battery voltage at the coil primary circuit? If this is low it will cause problems.
These are general suggestions which can be fine tuned if you can tell me the type of system is fitted to the car - Bosch LH Jetronic or Volvo/Chrysler Hall effect.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
imaraiza
Post by imaraiza »
losing my negtive pulse on the coil and do have a positive pulse on the battery
Boshc Halefex Distributor system is what is on there
How so I confirm tha it's not a fuel relay
or control module?
I hope to solve the issue so people can reference this data.
Regards
Thanks - 240DL
