ABS light and the Trac light are lit
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2655 times
Been thanked: 1248 times
Post by matthew1 »
[This thread is a breakaway from another, non-related thread.]
TomPaol:
I am trying to find out why the ABS light and the Trac light are lit. I have just had all new brakes put on. Is this just a short somewhere? Where do I start looking?
Ozark Lee:
There is a 99% chance that you ABS problem is the ABS module itself. All of the post '95 modules fail at some point.
You can either get the module rebuilt by Victor Rocha, Module Masters, or the eBay guys. If you are decent with a soldering iron you can fix it yourself for free.
https://www.matthewsvolvosite.com/chat/p ... 6827#46827
PS - I am not a moderator here or anywhere else but you might just want to post a new thread the next time you have a problem unless it is a real current thread that you are jumping in on.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
I agree that 99% of the time it's the module but if you just changed parts close to the wheel sensors, it would be worth checking those sensors. If you have a ''93-'95 850 you can check the specific ABS codes under the dash by way of the diagnostic box.
BEJinFbk
Year and Model: '98 V70 R
Has thanked: 93 times
Been thanked: 146 times
Post by BEJinFbk »
MadeInJapan wrote:I agree that 99% of the time it's the module but if you just changed parts close to the wheel sensors, it would be worth checking those sensors. If you have a ''93-'95 850 you can check the specific ABS codes under the dash by way of the diagnostic box.
Here's Victor's page. Good info!
http://home.earthlink.net/~vicrocha/
TomPaol
Post by TomPaol »
OK thank you. This is a 1997. I would like to attempt this repair myself. But is there some diagnostic tool I should have that will pin point the problem? Or is trial and error for diyer?
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
On a 1997 the only way to read fault codes is with a Volvo Scan Tool or its equivalent.
A dealer can read fault codes for sure but I have no idea what they would charge. A good independent shop would likely read them for less money.
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
Ozark Lee wrote:On a 1997 the only way to read fault codes is with a Volvo Scan Tool or its equivalent.
Don't waste your time, it's the module
Send it out for a rebuild, EVERY SINGLE ONE FAILS
TomPaol
Post by TomPaol »
OK Lee thank you
