Hey guys,
got a call from the mechanic today saying that my 88 760GLE's brake booster wont hold the vacuum overnight. He called over to the Volvo dealership next door, they wanted ~750$ for a new one. So, I quickly checked FCP Groton and they have one for about half the price. IPD had one, but it was for vehicles without ABS.
Is this the best way to go, without going for a rebuilt booster from somewhere like here: http://www.racepages.com/products/?Ntt= ... er&N=11867 or would a rebuilt one not cause too many problems.
760 Power Brake Booster
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I go along with sseir39 on the used item.
Did the mechanic tell you what the problem was? The only time I saw a problem with one of these it was the seal behind the valve. We replaced that and it held vacuum.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Probably you have the same brake booster as the 740 series. It is a common problem that you have a leak where the vacuum hose is attached to the brake booster. That is just some sort of conical rubber cone pressed into the booster canister, supposed to be air tight. Very often, this simple connection is leaking.
Cheers for the help all...
I picked up the car yesterday. Because it was a very slow leak, my mechanic was able to re route the vacuum line so that the booster had sole access to it, thus avoiding having to replace the unit.
Thanks for the advice again, everyone
Darrell
Darrell
- billofdurham
Glad you are safely mobile again.
Thanks for the update.
Bill.
Bill.
Previously:
Previously:
- 631 Views
Last post by themtnman369
- 4732 Views
Last post by SUBdude
- 6990 Views
Last post by 850forum
- 800 Views
Last post by louie3888
- 2604 Views
Last post by DraftyBread
