When I have the AC/ or heat on and the blower on at any setting, when I accelerate the blower slows down almost to no air flow. What could be causing this and how can I fix it?
Thanks for any help
Van I
Blower motor slows when under acceleration
My thinking exactly. The problem is probably not the motor, but actually a vacuum leak causing the ventalation system to "change" to defrost under accelleration. Check for loose hoses, also check the function of the one-way-valve from the vacuum resevour
