S40 Spontaneous Reving, Idle Problem When In Drive
1996 - 2004 S40
1996 - 2004 V40
ragingbull22
Post by ragingbull22 »
Wondering if anyone has ever experienced this problem:
2000 Volvo S40 1.9T
103,000 miles
Recently serviced, new timing belt, new fuel filter, new engine mount.
The problem began in park while idling. The engine began to rev to 1,500 - 2000 RPM on its own and than come back down to normal idle. It did this spontaneously many times. Thinking I could reset it by tapping the accelerator, instead it reved up to 3,000 and never came back down, I had to immediately shut down the engine. At that moment the car did not want to start until it cooled off 30 minutes later.
The problem worsened when it started happening in drive, stopped at a light or rolling the car spontaneously reved and lunged forward on its own for a few seconds and than back to idle. The first few times I had to slam on the brakes to avoid slamming into the car in front of me.
I drove a few miles, parked the car and suddenly the coolant overflowed out of the reservoir spilling out a good amount. I let the car cool off, refilled the coolant reservoir and got the car home. The coolant did not spill over in the 5 mile drive again but the car continued to spontaneously rev on its own and lunge forward and finally the check engine light came on as I pulled in home.
Anyone have a clue what is causing this? Faulty sensor, faulty valve? Could this be an overheating problem?
The timing belt was recently changed (2 weeks ago) by Volvo, could this have anything to do with it? The car didn't feel the same when I got it back, slight chirping sound coming from belts.
I am really lost on this one.
Thanks in advance for your help and appreciate any replies, suggestions, comments.
volvo741
Year and Model: 2003 s40
Post by volvo741 »
My s40 just started having similar issues with the spontaneous high reving and lurching actions at a stop.
I'm planning on researching into the issue further.
jpravi8tor
Year and Model: S40 2001
Post by jpravi8tor »
Panic call from daughter car is accelerating by itself up to about 2k rpm with foot off accelerator then it starts to overheat. She shuts off car and it is hard to start. what in the world is happening?! Car is 2 hours away cant check it until tommorow
