Erratic Idle on 1991 240 sedan
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Ragman
Year and Model: 2012 XC70 T-6
Post by Ragman »
I've been working on a 91' 240 sedan with 240k kilometers on the clock. It has a K&N air filter, Magnecor wire set, Bosch platinum plugs,new cap, rotor, screens removed from mass airflow sensor and most recently frt &rr pads,rotors,and calipers and a fresh fluid bleed with new flexlines,etc. With the engine running, when I step on the brake pedal, the idle surges and settles again when I release the pedal. I read on the IPD site about the brake booster fitting sometimes causing a vacuum leak and was wondering if this might contribute to the idle surge. Any ideas or input is appreciated.
86 740T M, 98S70T-5 M x2, 07 V70 2.5T
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
It certainly sounds like what IPD describes.
goldmember
Post by goldmember »
get the screens back on the MAF. It won't take much to damage those very fine wires.
Let us know if you fix the problem.
Cheers
George
Gold Member is our Gold 91 740 Wagon
