95 volvo 960 radio code will not turn on radio
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
wright
Post by wright »
car radio code will not turn on radio, car was brought to volvo today and tech gave me the code for the radio please help
DeRail
Year and Model: None
Post by DeRail »
Have a look over here: https://www.matthewsvolvosite.com/radio.php
If that doesn't help you out, give a post back here and we'll see if we can't help you out :)
Cheers
DeRail
bigfinn
Post by bigfinn »
Make sure the ignition is on in order for it to accept the code.
IPD Sport Springs. Koni Yellows. IPD endlinks. IPD strut bar.
160,000 miles
JRL
Year and Model: Several
Been thanked: 16 times
Post by JRL »
If the radio says "CODE" and it doesn't work, you have a replacement radio
If it says "OFF" you must get it back to say "CODE" for it to work.
If it says OFF you have to leave the key on for over two hours or drive the car for two hours without turning off the key. It then should reset to "CODE"
If it IS saying CODE now and it doesn't work, pull the radio and IM or email with me ALL the numbers on the radio (both sides)and I'll get you the right code for that radio.
If you don't know how to remove the radio, get in contact with me and I'll tell you how to do it
Jim
jrl1194(at) aol.com
