I had stopped to look for the cause of the creaking when turning right. It appears to be the shocks.
I digress from the real issue, the driver's door-stop torx screw bolt has snapped off , obviously a case of metal fatigue.
It looks like an easy fix.
I think I should be able to drill out the remaining bolt and replace it with a new one. That is if they used a non-diamond type material.
If anyone can shed some pearls of wisdom on this issue I would be grateful.
Some pics of the little bast..d bolt:
and the stop hinge and bracket
