1994 850 rear lower shock mount bolt snapped
IG-88A
- Year and Model: '94 854T-'95 855GLT
Now what?! I'm so irritated right now. It came off no problem, and then when I tightened it down, snap! I hadn't even got it down to spec yet. How do these even come out?
- Year and Model: Many Volvos
- Been thanked: 76 times
Pretty much. The good news is that the delta links are pretty cheap at the junk yard.IG-88A wrote:Upon further review, looks like I'm screwed.
IG-88A
I was able to get two or three threads of a nut to grab onto the stub. Maybe that'll get me to the shop without too much rattling.
We have had a member that have had a shop weld a new stud on but it wound up being a bigger hassle than just changing the trailing arm. The factory stud is tapered and the straight bolt replacement never held the shock on properly.
I just had to deal with this. I used a dremel tool with a grinding wheel to grind the diameter of the stud down to 12mm a little past the thread. I then used a die to cut the threads deeper. This allowed for a lug nut with a tapered face to get more thread engagement. I haven't driven much like this. Hopefully it holds up.
This is with a Nivomat shock which has tapers in the bore for the lug nut to nest into. I am assuming the standard shocks have the same taper on each side of the bore, but if for some reason they don't this probably wouldn't work.
- 1622 Views
Last post by GLG
- 2579 Views
Last post by darrylrobert
- 876 Views
Last post by leucadiacruiser
- 1782 Views
Last post by MoVolvos
- 926 Views
Last post by GreenMagicMan
