1990 240 DL 230Fengine
littlebritches
- Year and Model:
Installing a new timing belt. Have located the the marks for the camshaft and idler need to know where the crankshaft marks need to go? The crank has both a concave and a convex keyway. Where are they suppose to line up. I inherited the car and the car was bought in munich new, serviced regularly till 100k miles shows 171k miles. want to make a daily driver if possible.
- Has thanked: 17 times
- Been thanked: 35 times
wojeepster
- Year and Model:
save yourself much aggravation and line up all the marks before you remove the old one. That way you will know what it should look like. You need a special wrench or some other method to hold the bottom pulley while you loosen crankshaft bolt.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Failing the special wrench remove the starter motor or the flywheel bottom cover and have an assistant jam the flywheel whilst you remove the crankshaft bolt.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- 893 Views
Last post by maverill
- 1001 Views
Last post by johnny volvo
