Passenger door won't open on 94 850 estate/wagon
the passenger door on my 94 850 estate will not open from the outside but does fine from in the inside. the door locks and unlock electrically just fine. any ideas?? I also took off the panel and did not see anything out of the ordinary but was not quite sure what to look for. Cheer, Rod
- Has thanked: 17 times
- Been thanked: 35 times
Hey Rodfarah,
You may have to go through this to confirm your real issue with your door:
https://www.matthewsvolvosite.com/chat/p ... hp?t=11338
I also have a 94 850 wagon and have the same issue on my rear drivers side door, but it is intermittent. I find that if I lift up on the handle while pulling it out it opens almost every time. May not help you but worth a try.
05 V70R TiKap (so happy) 91K
05 XC90 2.5T FWD TiBlak 97K
94 850 wagon 2.4 (N/A) 155K (Sold running like a champ)
latigerlilly
- Year and Model:
I suspect a broken child safe door latch. Rear doors have this not the front seat doors. Look where the door meets the car on the door side. There is a latch that you flip up or down. One position is child safe (door doesn't open) and another position is child unsafe (it opens). This prevents kids from falling out while vehicle is in motion. This is either broken or in the wrong posiition.
Please answer my question:
https://www.matthewsvolvosite.com/chat/p ... hp?t=15526
Thanks.
Thanks.
Current:
1998 Volvo S70
1988 Volvo 240
1998 Volvo S70
1988 Volvo 240
I did!latigerlilly wrote:Please answer my question:
Thanks.
I was able to get a used lock assembly for £20, instead of the £250 price from the dealer, and had it fitted for £30. Works like a charm. Continetal Breakers in UK sorted me out!
rodfarah wrote:the passenger door on my 94 850 estate will not open from the outside but does fine from in the inside. the door locks and unlock electrically just fine. any ideas?? I also took off the panel and did not see anything out of the ordinary but was not quite sure what to look for. Cheer, Rod
- 1144 Views
Last post by brick_and_motor
- 1211 Views
Last post by Mauiman
