Shocks and Struts - 850
niu2004
Post by niu2004 »
The suspension on my 95 850 is starting to go. The front right and back left has been clunking. Does anyone know where I can find information on doing this job myself? I am planning on ordering the parts from IPD.
AL
95 850 Turbo Wagon
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
You might want to check out
Import Replacement Parts
[email protected]
Order Line: (425)398-1846
Hours: Mon-Fri 9:30am - 5:30 PM, Sat 12-5 PM PST
www.importrp.com
Shocks:
Boge "Automatic"/Hydraulic Front Strut - $105 each
Bilstein Front Strut Touring Class - $78 each
Bilstein Heavy Duty Front Strut - $135 each
The Strut mount bushings are available in 3 brands:
OEM Spec - $26 each
Sachs - $23 each
Scan-Tech Sweden - $22 each
Comparison to IPD
Bilstein Touring Front - $126
Bilstein HD Front - $168
I have no relationship to either parts seller. All shocks are for 850s. Counterpoint: Remember, if you run into trouble, IPD will probably be available for phone support. The other shop... who knows. They sell parts for 40 different brands of car.
Also -> Amazon link
Stormin Norman
Post by Stormin Norman »
IPD is wonderful to do business with, knowledgeable, freindly and honest. Prices are not bad condsidering.
Geevs
Has thanked: 9 times
Been thanked: 2 times
Post by Geevs »
Here's a link on how to do the front struts
http://members.shaw.ca/heeeeee/strut/
Search the volvospeed.com forum on how to do the rear shocks. The rear is supposed to be pretty straight-forward and doesn't require messing with the springs.
T-Squared, if you are reading this pls advise if the front struts also use a bushing/mount ASIDE from the spring seats (as shown in your pictorial). I am kinda confused as to which parts to replace when changing the front struts. I understand the rears would need "rear shock mounts" (those oblong shaped rubber bushings).
Thanks,
Geevs
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
I haven't replaced a Volvo strut. I believe you have me mixed up with someone else.
Wish I could help.
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
Geevs
Post by Geevs »
Ooops, you're right I got you mixed up with someone else's post/pictorial.
Geevs
