1999 s80 t6. will faulty brake servo affect autobox
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
les & reilly
Post by les & reilly »
i am wondering if anyone can tell me if they have experienced problems with their geartronic or automatic gearbox because they have had a brake servo which has a hiss when the brakes are applied.
any feedback would be much appreciated
thanks in advance
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Hey Les, did you get your tranny fixed? What was the problem?
les & reilly
hiya vegas,
havent done much with it the last few days. before i tie a rocket to it and send it off to the moon, i am checking things out to rule out problems before taking it to the stealer dealer.
my faith in garages are poor because i have read so much on these and other forums that even the dealers have got the diagnosis wrong, ending up in a very big bill for the owner and the problem still not solved.
i am not sure if my car will need to go to the dealers to get the codes reset. i believe i may of fixed the problem, a broken wire to the gearbox, but i dont know if the codes have to be reset to get it into normal mode again.
it is still stuck in limp home mode and i have not got a choice of forward gears.
any suggestions, my dtc tcm screen reads "checking" ???
vegasjetskier
Have you tried disconnecting the battery cable from the battery for at least 30 seconds? I hear this is supposed to clear some codes.
les & reilly
hiya vegas,
i have had the battery disconnected overnight and it is still storing the codes.
i think i am going to have to get the codes cleared by the stealer.
les
