sway or strut?
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
elcs70
sway or strut?
Post by elcs70 »
this may sound like a foolish question to some, but i have been wondering as to what the difference is between and anti-sway bar assembly and a strut brace is. thank you in advance for your time.
1999 s70 AWD LPT
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Antisway is under the car and puts tension on your suspension from below. The strut brace is above the struts, on the strut towers, binding them together and is located under your hood. Hope this helps.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
The strut is the vertical component of the suspension that absorbs road shocks while allowing the wheel to turn back and forth.
The anti-sway bar connects both struts together across the car. As the car enters a turn and the strut on the outside of the turn compresses, the anti-sway bar transfers pressure to the inside strut. The purpose is to reduce body roll.
The strut brace goes across the engine compartment between the tops of the two strut towers. Its purpose is to keep the struts in alignment with each other as pressure in a turn may cause the body to flex, changing the suspension geometry. The brace resists this pressure and keeps the geometry the same.
elcs70
Post by elcs70 »
thank you kindly. most helpful
1999 s70 AWD LPT
HadleyCooper
Post by HadleyCooper »
From what I know, swaybars can reduce the amount of body roll a car has have, which then increases the amount of tire contact that will keep in hard turns. In terms of suspension mods, swaybars are said to be the best bang for the buck. Meanwhile strutbars mount to the top of the struts and help keep the strut towers from flexing when turning hard corners. However, these won't necessarily give you any additional cornering force. They will generally make the initial turn-in of the car much more responsive though.
