Weird charging problem
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
blastinbob
Post by blastinbob »
I have a 88 240dl my charging problem consists of this when I put it on a meter running it shows 13 volts and when I disconnect the battery it goes to 14 like it should I have tried 2 batteries and it is not that when I turn on lights it goes to 12 and eventually kills the battery this is also the 2nd alternator and it seems ok with batter disconneted any help would be apprecitated.
LaRy
Post by LaRy »
Check the grounding of the engine. From the car body it is going a blue thick cable to the battery minus pole, continouing to the starter. This cable can be dammage by corrosion or broken by vibrations. Especially when passing under the front underside of the engine. Probably you have one more ground connection at the back top of the engine. You seems to have a voltage meter. Check with the voltage meter if you have a voltage difference between the engine block and the car body. If you have a clear difference when the engine is running and the head lights are on, you have a bad grounding.
jeffrobodine
Post by jeffrobodine »
LaRy is right(as usual) i went through 8 thats right 8 before i figured out to run a new ground now its chargin perfectly.
