93 940 wagon nonturbo:AC control
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
This topic is in the MVS Volvo Repair Database » 850 Heated Seat Not Working? Here's The Fix.
Lou Rosenbaum
Post by Lou Rosenbaum »
While highway driving, passing or hard acceleration, the air will move from the dashboard vent to the floor vent. Let up on the gas and air moves back to dash vents. Very repeatable. I first thought it only happened when going up a hill. Wasn't till I was passing on level ground that I realized it was not happening cause of the hills but because of hard acceleration.
Thank you for you attention
OUT OF MY LEAGUE LOU
"250,000"
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Is this the manual or electronic climate control system?
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Lou Rosenbaum
Manual climate control
billofdurham
The direction of airflow on the manual climate control is controlled by airflow mode doors which in turn are controlled by a vacuum actuator on the left side of the heater distribution housing. Their position is set by the centre knob on the control panel. As the airflow changes when you increase power to the engine I would suspect that one or more of the door actuators has a vacuum leak allowing it/them to move without you changing the controls. As the power comes off the engine it/they resume the proper position.
Bill.
Previously:
