96 850 code P1308 Mfg control ignition or missfire
petek153
- Year and Model: 1992 940T
Have this code that pops up instantally after starting car . Replaced plugs, rotor ,cap, wires but still comming up with this code 1308. Read on one site that it could be a faulty acceleration sensor ??? Looked through my service manual and couldn"t even find a mention of this sensor. Is there such a thing and could this be my problem? Thanks for your help.200000 miles and counting
- Has thanked: 17 times
- Been thanked: 35 times
Did a search and I'm just going to quote everyone from another site here:
Volvoboi24
"Hey guys, well I cleared the two codes I had, and the car seems to run fine.. I still have a check engine light on and its the same P1308 code. The generic OBD II reader that I used said it was ignition system problem, but someone mentioned it was actually the AC clutch circuit fault? can someone verify?
I also noticed water (not coolant or oil) coming down near the front bumper, would the AC clutch circuit fault cause this condensation? Thanks in advance everyone.
by the way, the AC works fine"
Bay13
"I think 1308 is for the Accelerometer signal too high. The Accelerometer is on the front part of the sub frame, just to the passenger side of center."
Volvoboi24
"Yeah, I think thats it, cause I noticed there was some sort of socket on the frame, but I dont know where the plug is that connects to it... do you know where that plug originates bay13 admin? thank you once again."
Bay13
Mar 5 2005, 04:13 PM
"It's not too far away from the sensor, As I remember it's not but a couple of inches after it comes out of the harness that runs along the top of the subframe."
Volvoboi24
Mar 5 2005, 07:00 PM
"Got it! the CEL is gone now, thanks Rich! smile.gif"
Volvoboi24
Bay13
Volvoboi24
Bay13
Volvoboi24
petek153
OK I believe i've found it !!!! for anyone like me who had never heard of it, its located on the front of the cross member just under the radiator offset slightly to the passenger side with a three prong connecter to it.It's low to the ground and yes mine was broke looks like a curb got it now to try to get a connector and sensor connector is also broke i'll keep everyone updated on results and try to get a couple pictures also.
I just got home after an ordeal with our Volvo 240....anyway, I answered your PM and then looked here and seems you've figured it out. If you can't find the part on line somewhere you might raid a wrecked Volvo at a junk yard near your house. If you can get the connector off, it's probably good. I never hear of these going bad.
petek153
Code 1308 is gone after replacing the acceleration module. I was able to find one on ebay after contacting a few sellers that deal with sensors. Volvo is not the only one that uses the acceleration sensor same part number is used on some huyndai's price paid delivered was $30 and works great.
Ah...nice find!
petek153
1308 was fixed but found that both o 2 sensors were reading bad. Just to let readers know that the "walker " brand from FCP Groton worked well at half the price of the Bosch ones Car now through emmisions and safe for another year.
Can you give ou the huyndai's part numer or any defining details?petek153 wrote:Code 1308 is gone after replacing the acceleration module. I was able to find one on ebay after contacting a few sellers that deal with sensors. Volvo is not the only one that uses the acceleration sensor same part number is used on some huyndai's price paid delivered was $30 and works great.
thank you
James
mattconrad850
- Year and Model: 1997 850 wagon
- Has thanked: 1 time
97 850 CEL P0450 and P1308 codes won't clear, started with frequent misfires, runs a little rough, then evap issues, found several real issues, broken hoses, clogged fuel filter, dirty dist cap, turns out vertical accel sensor is going bad too, found one here :
https://www.ebay.com/itm/Longitudinal-A ... SwLDlcWFy7
$38 + 8 ship, way less than $100 - $200 from other sites
it's located behind bottom of radiator on subframe slightly to right hand side, squarish has 2 bolts 8mm look for connector
- 3245 Views
Last post by Lurch
- 2839 Views
Last post by aswresm
- 2165 Views
Last post by wizechatmgr
- 13 Replies
- 4895 Views
Last post by shiloh51933
- 786 Views
Last post by krassigr
