Volvo 244GL power upgrade
How to go faster, stop quicker, and turn harder. Chips, exhaust, larger turbos, bigger/slotted/drilled rotors, high performance brake pads, manual boost controllers, performance shocks/struts/springs, airbox mods and more! Also discussion on HID and Xenon lights, aftermarket foglights and other exterior lighting.
Dauntless
Post by Dauntless »
Hello, I own a Volvo 244GL in Australia. It uses the B23E 2316cc 4 cylinder engine using mechanical injection, with 136hp. The engine has done 300,000km (185,000 miles) I am looking for about 170-180hp from this engine without turbocharging or supercharging, and i am on a budget.
What do you suggest?
Thanks.
Volvord
Post by Volvord »
Your desired final HP would require about 1.25HP per cubic inch displacement, anything over 1HP per cubic inch on a naturally aspirated engine and you have built a very healthy engine. You will be very hard pressed to achieve your final numbers at a reasonable price.
The B23E already has a fairly agreesive cam, and a good injection system running a freer flowing exhaust will help some. Good luck and have lots of fun.
http://www.Volvord.com
1998 C70
1989 744TI with a 400HP Ford 302 / 5 speed
