1998 V70GLT
Hi everyone, my wagon has had a problem for about a week+. It started the day I gave another car a jump. The other car didn't start, so my car idled maybe 10 - 15 minutes. Later when I was driving over the pass, my car started to blink CELs. It turned out to be Code 301, "#1 cylinder missfire". I've subsequentlly replaced the plugs, distributor cap & rotor, then finally the wires. Each time it would again throw the CEL Code 301. I'm now stumped, and hope someone out there has ideas on what I do next. My car has 214,000 miles, but has run great until then. Thanks ahead for any help.
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
One thing comes to mind. Did you erase the code?
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- Has thanked: 17 times
- Been thanked: 35 times
Could be your ignition coil on the side of the fender', in front of the air filter box...can you get a hold of another from a late model 850 or an S/V70 of the same year to see if there's a difference?
See what would happen if you put the old, "old" one back on.
I guess next thing I would try is switching around the plugs to see if there is any difference. Btw, what ignition wire set and plugs did you buy? Bosch wires are known to have this type of problem as do Bosch platinum plugs.
- 573 Views
Last post by astroman77
- 588 Views
Last post by mtrdrms
- 2020 Views
Last post by MrAl
- 1908 Views
Last post by bmdubya1198
- 1766 Views
