I was wondering if anyone has any advice (and possibly some instructions) for replacing the headlight lens on my 98 V70. Is it a problem to just change the lens instead of replacing the entire headlight assembly?
Thanks!
98 V70 headlight lens replacement
trammellclan3
- Year and Model:
- BEJinFbk
- Year and Model: '98 V70 R
- Has thanked: 93 times
- Been thanked: 146 times
Changing the lens is not too difficult.
There are about 8 or nine clips that hold the lens and gasket to the housing.
Since the bottom of the fixture is pretty tight against the bumper,
the whole operation is much simpler if you remove the entire assembly.
IIRC, there are 3 bolts that attach the headlight to the car.
Seems that I remember a walkthrough here or Bay 13...
It took about me an hour or so to pull mine and replace the lenses with eCode glass.
Check eBay, IPD and FCPGroton for new glass.
895meztz94
- Year and Model:
It's VERY easy to remove the headlights. Three 10MM bolts and a tug and you're finished.
I find it's easiest to remove the hood latches to get to the fender side bolt.
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
wow prices vary a lot
ebay $30
http://cgi.ebay.com/Headlight-Lens-98-9 ... 51926e7af5
FCP $40
http://www.fcpgroton.com/product-exec/p ... gory_id/24
IPD $75
http://www.ipdusa.com/product.asp?strPa ... rtRecord=1
Bap Geon want over $80
ebay $30
FCP $40
IPD $75
i have the scan tec E code lenses and they were like 45 or 50 a piece and they are still the 'hella' brand lenses if i recall correctly.
the lens looks fine to me. similar to the kit i got with the e-code ones.
I'm on for aesthetics as well and replaced both at the same time cause i cant stand one looking different
advice:
Keep the original gasket if its still good, and keep as many of the original clips because they seem nicer then the new ones provided.
advice:
1998 S70 T5 SE 214,001
1999 v70R 126,000
1999 v70R 126,000
- 4679 Views
Last post by XC70Rider
- 477 Views
Last post by Skymongrel
