Removing Steering Wheel Shroud: 1994 Volvo 850 Turbo
rthom
Post by rthom »
What is the trick to removing the steering wheel shroud on a 1994 Volvo 850 Turbo? I need to replace a broken turn signal lever. I have removed the 2 visible torx screws from the lower part of the shroud, but it still won't come out. Are there other screws I am not seeing?
Thanks, rthom
1991 740 Turbo (still goin' strong!)
1994 850 Turbo
1996 850 Turbo
2000 S70 SE
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
There are two other smaller ones - T-10 or T-15 - I can't remember off the top of my head. They are inset deep in the holes that directly in front of the steering wheel. The holes are small and larger sockets tend to get stuck if you use a 1/4" drive socket and an extension with the Torx bit. I have found that a long 1/4" nut driver with the Torx bit works better.
rthom
Post by rthom »
Many thanks, Lee. I could see those two deep holes and wondered if screws were hiding in the bottom. Now it's a trip to the store get a smaller Torx bit. Strange why Volvo wouldn't use the same size for all four screws.
Regards, rthom
1994 850 Turbo
1996 850 Turbo
2000 S70 SE
Sperry
Year and Model: 850 Turbo 1994
Post by Sperry »
You can barely reach the two [front?] screws with the
Volvo torx-driver [the smaller size] if you use it without the handle.
I was many miles from home when my ignition switch crapped out.
The screw was tight, but I could turn it with a good grip on the insert.
The Volvo torx driver is in the tool kit in the trunk.
1994 850 Turbo Sedan. 202,000, and getting more experienced, not older. - sold
rthom
Post by rthom »
Thanks for the input.
I managed to get the two front screws out with a T-15 Torx screwdriver. Not the easiest to locate in the deep slot, but with some patience you can engage the screwdriver.
There was no Torx screwdriver in my toolkit.
rthom
1994 850 Turbo
1996 850 Turbo
2000 S70 SE
MatDesign84
Year and Model: 1997,855 T5
Post by MatDesign84 »
You guys are making this harder than it needs to be. T-handle torx drivers are your friend. I think mine are 6" long. Just saying...
Currently: 1997, 855 T5 | 1998 Subaru Legacy GT 2.5
Previous: 1997, 850 GLT | 1993, 850 GLT | 1988, BMW 325i, 1990 Volvo 240 DL
"That's good to know though in case they let loose again, but I swear if they do, I'll punch something." -jblackburn
cpl
Year and Model: 1994 850T 2004 S60
Has thanked: 2 times
Been thanked: 2 times
Post by cpl »
Thanks for the information on how to remove the steering wheel shroud T25 & T15 just replaced one on a 94 850T easy job.
1994 855T Teal
2004 S60
2006 XC70
1990 F150 XLT Old Blue; I sure do miss Old Blue
