Removing fan shroud 850t
rguzz
- Year and Model: 1996 850 turbo
- Been thanked: 25 times
No such thing as a silly question but how do you pop the upper fan shroud (houses the relays) off, and up? I've tried searching but still isn't clear to me. I'd like to clean things up under there and access the intercooler hose. Thanks.
- sleddriver
- Year and Model: 1998 V70 T5
- Has thanked: 11 times
- Been thanked: 13 times
There are two Torx screws that need to be removed and two small bolts a few inches below them, on either side. The later will loosen the fan/shroud allowing you to pull it towards the engine a bit. Then you can tilt the right angle UFS towards the engine a bit, then pull it straight up after first removing the relays.
That's the way I do it on my 98 V70.
M1 10W-30 HM
M1 10W-30 HM
- Has thanked: 2857 times
- Been thanked: 1332 times
If you're having trouble with this, you're overthinking it. From this P80 replace radiator topic, which itself may provide more clues for you for the fan/shroud:
I pulled the fan and shroud up and out. I did the first two of four T25 screws (topside, captive), and facing more of that, said "There's GOT to be a better way." I pulled up on the fan and boom it came off the shroud. The bottom two screws are slide-ins
. Then the shroud came out easy.
- 900 Views
Last post by Antoine240bk
- 621 Views
Last post by PixelDust
- 2393 Views
- 599 Views
Last post by StickyPocket
- 643 Views
Last post by - Pete -
