Can anybody tell me if its possible to skim the head on an 850 t5?
After getting my local specialist to change the head gasket I am now being told that the head needs to be replaced because its warped and cannot be skimmed. Because I dont know if this is possible or not I'm having to pay out
Replacement head
- Has thanked: 2861 times
- Been thanked: 1332 times
I dinnae, sorry. Perhaps the folks in the RWD forum will know. There's a Volvo tech or two in there; I'm just a regular guy that works on his Volvo from time to time.
- Tsquared
- Year and Model: 11 C30
- Has thanked: 1 time
Milling the head is done to get the surface square. Aluminum heads are notorious for warping beyond the spec of safe milling. If were just a crack or blown plug/hole in the head it could be heli-arced to fix the problem.
As far as the intake with 3 cracks I would be leery of welding it up. The stress of the heating process may cause other micro-fractures that will develop into a serious problem later.
Anytime you pull an aluminum head off and engine it is going to be a costly affair. Aluminum is great for performance due to its lightweight properties. It is not very strong structurally.
good luck,
T
good luck,
T
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
- 13 Replies
- 8449 Views
Last post by lifeofgold
- 16 Replies
- 1969 Views
Last post by erikv11
- 1751 Views
Last post by goddess357
- 1230 Views
Last post by Brazuca_ny
- 16 Replies
- 3449 Views
Last post by Craigd2599
