1997 850 2.4 wagon (non turbo) vacuum diagram
wadeo611
Post by wadeo611 »
Help !!!!! I just found a disconnected vacuum hose under the injector rail just above the power steering pump, lightly pulled on it and the whole thing came out ! I can find turbo diagrams, but nothing for the non turbos. Any ideas ?
wade phyfer
[email protected]
1997 850 wagon 123k
Year and Model: Many Volvos
Been thanked: 75 times
Post by Ozark Lee »
Off the top of my head the only thing that I can think of in that area on a N/A is the fuel pressure regulator. Pop the cap off of the fuel rail and the regulator is on the end of the rail, more or less above the thermostat. To get the cover off of the fuel rail just grab it and lift up.
wadeo611
Post by wadeo611 »
I found the connector on the intake, nice and tight. i pulled the fuel rail and still couldnt find where this hose connects.the other side seems to go toward the trans / air box assy. i think i hear a vacuum leak from under the p/s pump, but cant be sure.
tailor
Year and Model: 2004 XC90 2.5T AWD
Been thanked: 2 times
Post by tailor »
One possibility is the connection on the intake manifold,(but methinks you found that one) left hand side when facing the engine, it is highlighted in red on this diagram, even though this is for a 98 turbo, it is just for position.
Did you take a peak at the diagram on the hood of the car near the passenger side hinge? You should have a diagram to guide you.
1994 850 Auto Turbo wagon 306000km (Sold)
2004 XC90 AWD 188000km
"Life is like a reel to reel tape recorder,
the closer you get to the end,
the faster it spins."
Abe Gottschalk
confused_al
Year and Model: 1996 TLA wagon
Post by confused_al »
...under the injector rail just above the power steering pump...
I can only find one vacuum line in that area of my 95 n/a, which runs to the "flame trap" of that air intake.
96 850 Platinum Wagon
98 MB ML320
06 V70
95 850 GLT(RIP)
wadeo611
Post by wadeo611 »
Grandma had a vacuum leak repaired 3 yrs ago, according to volvo. they replaced the elbow and 3+ feet of vacuum line. Im thinking they may have left the old line in. After looking at all of the diagrams, there is only one line coming from that side. Also, the only code i occasionally throw is a p-410 code that i think have traced to the secondary air pump relay (cleaned contacts and no code for over 3k miles ) Thanks for all that have posted. i've learned very rapidly that old volvo owners are somewhat cultish. websights like this will keep this old girl running for a long while. THANKS !!!!!!!!!!
wade phyfer,
[email protected]
1997 850 n/a wagon 123k
wadeo611
Post by wadeo611 »
P.S. I inherited this car from my grandmother. my mother has a 1989 740 gl wagon with 200k. even though the interior is falling apart, I think the 740 will go alot longer than the 850.
wade phyfer
[email protected]
1997 850 wagon n/a 123k
