Blower motor noise
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
Cossack
Year and Model: 2007 S60R
Blower motor noise
Post by Cossack »
Hi
My blower motor is making a whining noise, particularly early in the morning when it is cold. Last time this happened on my 850, it was a tell-tale sign that the motor was about to die.
I found a kit to replace the brushes in the motor - Has anybody ever performed this repair? Does it do the trick? How easy is it?
Thanks for any advice on this
2006 S60R MT
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Why do you suspect the brushes? Usually when they go there is no warning whine, the motor just stops.
On my 850 the whine was a dry bearing on the motor shaft. That was over 2 years ago. I pulled the motor out, lightly lubricated the bearing with a silicone based grease and put it back together. It is still whine free.
On the S60 you need to remove, on the passenger side, the sill trim panel, the soundproofing panel, the side panel on the centre console and the glove compartment. Detach the drain hoses from the motor and the filter housing and move them aside. Fold the carpet back from the front edge. Detach the connector to the motor. Remove the 5 screws holding it in place and pull the motor out.
From there you can decide if the brushes need replacing or if the problem is something else.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Cossack
Post by Cossack »
OK thanks Bill. I'll give that a try first. I'll post an update when I get it done.
2006 S60R MT
instarx
Year and Model: XC70 T6 2011
Has thanked: 1 time
Post by instarx »
I agree with billofdurham, usually whinny motors are caused by dry bearings. The less you run it like that before lubricating it the better chance it can be fixed with oil/grease alone. The whinning is vibration which is really bad for the bearings
Although it may not be possible, if it were me I'd at least look to see if either of the shaft bearings could be reached with some spray lubricant before going to the trouble of taking the motor out.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
Cossack
Post by Cossack »
I have the motor out but I am not sure where to lubricate. The fan wheel cover the top of the motor, so only the trailer bearing at the bottom of the motor is accessible. Any thoughts? :?
2006 S60R MT
