Hi
My blower motor is making a whining noise, particularly early in the morning when it is cold. Last time this happened on my 850, it was a tell-tale sign that the motor was about to die.
I found a kit to replace the brushes in the motor - Has anybody ever performed this repair? Does it do the trick? How easy is it?
Thanks for any advice on this
Blower motor noise
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Why do you suspect the brushes? Usually when they go there is no warning whine, the motor just stops.
On my 850 the whine was a dry bearing on the motor shaft. That was over 2 years ago. I pulled the motor out, lightly lubricated the bearing with a silicone based grease and put it back together. It is still whine free.
On the S60 you need to remove, on the passenger side, the sill trim panel, the soundproofing panel, the side panel on the centre console and the glove compartment. Detach the drain hoses from the motor and the filter housing and move them aside. Fold the carpet back from the front edge. Detach the connector to the motor. Remove the 5 screws holding it in place and pull the motor out.
From there you can decide if the brushes need replacing or if the problem is something else.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
- instarx
- Year and Model: XC70 T6 2011
I agree with billofdurham, usually whinny motors are caused by dry bearings. The less you run it like that before lubricating it the better chance it can be fixed with oil/grease alone. The whinning is vibration which is really bad for the bearings
Although it may not be possible, if it were me I'd at least look to see if either of the shaft bearings could be reached with some spray lubricant before going to the trouble of taking the motor out.
2011 XC70 T6 - current
2017 Alfa Romeo Giulia Q2 - Totaled in 2022. Not my fault.
2011 XC60 - sold
2000 V70XC - given to a friend, wish I still had it.
2011 XC60 - sold
