Hi guys. I services my 850 the other day. I also changed the coolant. Since then it looses its coolant. At first I thaught I didnt do the cap up tight enough. But I have since seen it makes little bubbles into the expansion tank through the little return hose. Is it common for these to blow head gaskets? And how easy or hard is it to do a head gasket on one of these? Its a 1994 850 Turbo 2.3l. I am a digger mechanic by trade, so I know my way around engines, I just hate working on cars...
Thanks guys!
850 Turbo blown head gasket?
stanley_changuion
- Year and Model: 1998
Stanley Changuion
Palmerston North, Manawatu, New Zealand.
1994 Volvo 850 Turbo
1966 Volvo 122S B18B
- Year and Model: Many Volvos
- Been thanked: 76 times
Unfortunately yes, it is a common problem. Particularly if the car has been overheated.Is it common for these to blow head gaskets?
Before you just tear into it I would have a leakdown test done on it to verify the problem. The Haynes manual is an excellent resource if you decide to change the gasket. The head gasket kit costs a little over US $100 and then you will need a full set of head bolts that run about US $3.00 each.
The Haynes shows how to make the special tools to keep the cams aligned when you put it back together.
Kmaniac in California USA
- Year and Model:
Bubbles in the expansion tank indicates the possibility that exhaust gases are leaking into the cooling system. This could be caused by a leaking head gasket, or one or more cracks in the cylinder head, or one or more cracks in the cylinder walls.
Before you tear it down, get yourself a "Universal Block Tester" to test for exhaust fumes in the coolant. It contains instructions on how to determine which cylinder is leaking if in fact there is a leak. Also, for good measure, do a compression test to check for pressure variations between cylinders. When you pull the head, take it to a machine shop and have it inspected regardless of what you think the problem might be.
I had the same thing happen on my "turbo-equipped" car (not a Volvo) and the problem ended up being cracked exhaust valve seats on every cylinder. Check your turbo to make sure the wastegate is opening as it should. A stuck wastegate or over-boosting turbo will burn up a cylinder head real quick.
Let us know what you find and what you do.
Chris the "K MANIAC"
1986 740 GLE
(5) 1964 Chrysler 300-K's
1986 740 GLE
Hello Stanly...
Before you assume a blown head gasket...some aeration of the water in the coolant tank is normal.
If the car hasn't run hot...I might look as some other causes before I pulled the head.
These cars do seem to have problems with leaky heater cores...I've replaced them in both my 850 and V70. My coolant loss was small but there was a detectable odor with the heat on. Some post here have had pretty substantial leaks there.
At least the heater core is an easy job!
Check the turbo coolant hoses etc. for leaks or stains that might indicate leaks there as well.
Take Care..
ED
Take Care..
ED
Ed
1995 850 turbo wagon 340,000
2000 v70 280,000
2002 v70 140,000
2000 v70 280,000
2002 v70 140,000
stanley_changuion
Hi again. The coolant definately comes out of the expansion tank cap. And it looses it over about three days, enough for the warning light to come on. It never overheated, the guage always stays in the middle.
Thanks
Stan
1996 Volvo 122S B18B
Thanks
Stan
Stanley Changuion
- Has thanked: 17 times
- Been thanked: 35 times
You could just have a leak in the expansion tank or one of the hoses under it...take it loose and have a check. Replacement of either is relatively cheap.
I had a blown headgasket about 2 years ago. It was caused by one of the coolant lines going to the heater core breaking. This caused the car to overheat and the head to warp. The engine wouldn't start untill the head was plained and a new head gasket installed.
If your engine is still running ok I'd check the compression in the cylinders and go from there. I can't remember the exact price but I know the gasket set was priced reasonably through FCP groton.
Japedo 94 850 turbo 470kms
01 V70 XC 121miles
95 Jeep YJ (plow truck)
01 V70 XC 121miles
2003 v70 2.5tawd black/black 120miles
2007 nissan altima 2.5 cvt 107miles
2001 xc70 211 miles " collision"/ parts car
1994 850 turbo 315miles 5 speed "stoped fixing it"
wolfspiritky
- Year and Model:
If there is a leak down into a cylinder you should be able to detect the "sweet" odor of coolant in your exhaust. If you "know your way around an engine" you should know a compression check is one of the first tests to be done.
Good Luck!!
Good Luck!!
00 S80 T6
97 850R
94 850 GLT-Totaled!
97 850R
94 850 GLT-Totaled!
wheelsup
- Year and Model:
- Has thanked: 16 times
- Been thanked: 22 times
Out of curiosity is this something that I would know right away or does it manifest itself? My car overheated when it blew a radiator hose about 4 months ago and then overheated again 1 month after that due to a bad fan relay. All at low speed. So far it's been OK, coolant level is the same, no other symptoms. Just wondering if I should expect this in the future or if it were to happen it would've already?Ozark Lee wrote:Unfortunately yes, it is a common problem. Particularly if the car has been overheated.Is it common for these to blow head gaskets?
-matt
(crossing fingers!! I hear head gasket repairs are expen$ive!)
- 1355 Views
Last post by lummert
- 1967 Views
Last post by tryingbe
- 905 Views
Last post by Wvusaxplayer
- 14 Replies
- 3069 Views
Last post by jcdillin
- 2046 Views
Last post by crussell83
