I did a search and found this discussion at another Volvo forum site: http://www.volvoforums.com/m_41054/tm.htm and followed a couple of the links to Vovo parts suppliers.
The existing front pads on my 1999 S80 T6 grab very well but produce a lot of dust and seem to wear out very quickly.
Most comments seem to indicate that non Volve i.e. third party pads cause a lot of squeeling noise.
Has anyone found/used third party/after market pads which maybe don''t grab quite as well but adequately and which produce less dust and last a lot longer the the OEM''s?
I do notice that the rear pads, which of course do a lot less work, don''t produce anywhere near as much dust as the fronts and also wear a lot less.
Has anyone, for example, tried the Akebono part#EUR794? http://www.akebonobrakes.com/aftermarke ... index.html
Thks.
Brake pad recommendation 1999 S80 T6
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
- Has thanked: 17 times
- Been thanked: 35 times
I always just use OEM pads but I have 70 series cars. I just put up with the dust and switch out my own pads- it's easy. But I have read a lot of good things about the Akebono pads. Good luck!
- 2916 Views
Last post by styoung94
- 12 Replies
- 2524 Views
Last post by drgswede1978
