92 B230 F engine timing
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
haroldburbank
Year and Model: 1992 240
Post by haroldburbank »
I just inspected my 92 B230 F engine timning belt and decided not to replace it. I disconnected the coil wire while spinning the cam pulley and thus the belt for on-car inspection. I reconnected the coil wire and the engine will not start, though it coughs like it wants to. Did I cause the belt-cam to jump time by spinning them on the car?
HB
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
If you only rotated the engine without releasing the tension on the timing belt the belt should not have jumped on the cam. If it has then the belt does need to be replaced because that would indicate that it is stretched.
Check the timing marks to see if it has jumped.
Was it the high tension coil wire you removed? Has it seated properly when you reconnected it? You may have damaged it if it is old.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
haroldburbank
Thanks. Will see if rotor lines up with #1 at TDC.
HB
