940 turbo 1992 intermittent power loss
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
kidbopblues
Post by kidbopblues »
Hi
Something weird happened to my 940. Drove home fine. Next day started, but had little power. limped it to the gas station, added gas. about 1 mile of driving and it ran better. Drove about 20 mile and got weird again, Added a few more gallons of gas and it worked okay for a while and did the same thing. Fuel pump relay is okay. But- could this be one of the fuel pumps?
Also-just before that, the heater motor fan stopped working, worked again for a day or two and quit. I have no idea if these two areas share any electrical systems or if it simply a coincident. Any one got any ideas? Thanks!! By the way-the car will run. but not with gusto!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The heater fan and the fuel pumps do not share any electrical systems.
You certainly could be experiencing fuel pump problems or it may be something much simpler like a blocked fuel filter. How long is it since that was replaced? It should be done every 60,000 miles.
On your car, to simplify diagnosis, there is an on-board diagnostic unit beside the left strut tower. You can use this to see if any fault codes have been set by the control unit.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
kidbopblues
Thanks Bill.
The problem appears to be solved for now! after reading another thread, I checked the air intake filter box and it had some maple tree whirlygigs in it!-so I took it apart the tube leading to what must be an air metering device- and it was full of debris!. I am not sure how it got there. So one lesson learned-trouble shoot before making the parts guys rich...
billofdurham
Good to know you're good to go.
Thanks for the update.
Bill.
Previously:
