1988 760 turbo starting problem.....HELP
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jag
Post by jag »
I'm having problems with the car starting... the fuel pumps/filter has been changed. It ran for a few days after the pumps were changed but now won't start again. running out of things to check. Fuses are not blown. there are 2 relays located under the hood not sure if these are for each fuel pump and how to check them? any help would be great. thank you
ozzimark
Post by ozzimark »
are you sure the fuel pump/filter was installed correctly? what kind of starting problems do you have? be a tad more specific. and when you get it started when it's having problems, how does it run?
