The idea is to try and make the diagnostic reading and resetting of codes a little less cumbersome.
I had a look at the Autoxray AX6000 , it appears to do everything including making you expresso in the morning,
My current vehicle is 94 850 TurboWagon, OBD1 and I have the OBD11 port as well, I tried an OBD11(only) scanner without success.I got an error code so I have to assume that the vehicle is not OBD11 ready. I am not sure if the Equus 3120 Innova Diagnostic Code Scanner with Freeze Frame Data for OBDI and OBDII (Post-1996) Vehicles would work, any thoughts on this ?
https://www.matthewsvolvosite.com/volvo- ... cessories/
At 150.00 it is a good price at this point and might be the easiest route to follow.
My wife drives an Envoy 2002 so I could also use it for that vehicle as well. At some point I would like to upgrade to a newer model( car that is
The other route:
I have Vadis discs and wonder what I would require as far as cables and extra software if i installed Vadis on a Mac or PC laptop. I am not sure if funtionability is dependant on the version of the software. Will I have any functionability, for example, able to read and or reset codes and what they would encompass ?
As always a big thanks to those who respond.
Tailor
