740 HandBrake: Adjustment or Shoes?
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
petershen1984
Post by petershen1984 »
Hey guys, I always forget to ask my mechanic to check my handbrake cable. (I need a To-Do list everytime I visit, it took me 1,000 kms to finally get them to readjust my idle speed). It travels very far, more than just a few clicks. On an incline, it cannot hold the car still on anything less than the last click. If I have it up to say, 5-clicks (where I think it should be), I feel absolutely no resistance with the car coasting in Drive at idle speed.
I know handbrakes are seldomly used with automatics, but my concern is whether this is just an issue with tightening the cable, or overworn rear shoes? (i.e. someone rolling downhill and forgot to release the brakes?)
BONK.
Peter Shen
1992 Volvo 960 (Silver)
LaRy
Post by LaRy »
Maximum number of clicks should be 11 and after adjustment, it should be 3 - 5 clicks.
ozzimark
Post by ozzimark »
yeah, mine does that too... i'm constantly tightening it, but i think that there is a combination between the brakes wearing down and the cable stretching that is always loosening it. just go in underneath that centre console from the back seat of the car, and you'll see the nut for tightening it, it's not too hard.
potroast
Post by potroast »
you can also tigthen the brake at the drums. Remove both rear wheels (with the car on stands) and you can insert a screwdriver into the drum to adjust the emergency brake. Sometimes it takes a combination of this and the above mentioned procedure to get a properly working parking break.
petershen1984
Alright, so the verdict for my car is:
Applied Force: "Drive" position at idle speed.
Operating Range:
Total Number of Clicks to Top: 11-12.
0-9 clicks: no effect
10 clicks: some resistance
11 clicks: able to hold the car still.
And I realized that the handbrake indicator is simply set off by a small button that the lever presses when it's down.
Do the hydraulic brakes activate the same shoes, or are they independent?
Peter Shen
LaRy
Post by LaRy »
They are totally independent. The brake for driving is a hydraulic disk brake with pads and the handbrake is a totally mechanical drum brake with brake shoes.
petershen1984
Well I couldn't get it any tighter than 8 clicks to the top, because the cable may be aged.
Peter Shen
LaRy
Post by LaRy »
I suppose you have an automatic and the parking brake is used very seldom. Then the wire should keep it
bluepilgrim
Post by bluepilgrim »
Just got a 1990 740 wagon (with a Haynes book), but it still took a while to figure out how to adjust the hand brake. I saw this forum the other day, but it didn't help too much, so I'm posting what I found.
The ashtray/ seatbelt housing just comes out by prying the sides out and top down -- there a couple of tabs at the top that need to clear. What I found looks a bit different that in the Haynes book. There was a big horizontal hex-nut shaped thing towards the front, and I could pull that back and tighten it by hand (top of it goping towards the right to tighten). Got it up to about 7 or 8 clicks like that. No big deal now that I know how.
I'm guessing that when the brakes are done this should be loosened and tightened up at the wheels so that the whole travel of the adjustment mechanism is retained.
