2001 s40
For the life of me, I cannot remove the two bolts holding the horn pad on...They are in back of the steering wheel. The manual says T30...I have tried everything...smaller, square drive, etc. By now, I have probably done damage to the insert.
Problem is, you really can't see the bolt head through the back of the steerer.
Anyone? Please?
Can't get the horn pad off...
- Has thanked: 17 times
- Been thanked: 35 times
I believe T30 is correct...they have to be centered exactly...they will be tight.
You could, and then just replace them, but even drilled out, I'm not sure how easily you're going to get the bolts out.
Anyone have another idea here?
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
I remember reading that these screws are in at an angle of 45 degrees and not just straight ahead.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
